The fieldCoordinateSystemTransform function object is used to convert a field from the global Cartesian system to a local user-specified co-ordinate system.
| input | {vol,surface}<Type>Field(s) | $FOAM_CASE/<time>/<inpField>s |
| output file | - | - |
| output field | {vol,surface}<Type>Field(s) | $FOAM_CASE/<time>/<outField>s |
Example of the fieldCoordinateSystemTransform function object by using functions sub-dictionary in system/controlDict file:
To transform the global velocity into a local cylindrical system defined by
origin: (0 0 0) axis: (0 0 1) radius: (1 0 0)
the following entries may be used:
transform1
type fieldCoordinateSystemTransform;
fields (U);
coordinateSystem
origin (0 0 0);
coordinateRotation
type axesRotation;
e3 (0 0 1);
e1 (1 0 0);
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: fieldCoordinateSystemTransform | word | yes | - |
| fields | Names of the operand fields | wordList | yes | - |
| coordinateSystem | Local coordinate system | dict | yes | - |
Each input field is transofrmed into a field with the name:
<field>:Transformed
For the example above, the U field is transformed into
U:Transformed
which is registered to the mesh database and written to the time directories according to the writeControl entry.
