The fieldExtents function object computes the spatial minimum and maximum extents of an input field.
The extents are derived from the bound box limits after identifying the locations where field values exceed the user-supplied threshold value.
| input | - | - |
| output field | - | - |
Example of the fieldExtents function object by using functions sub-dictionary in system/controlDict file:
fieldExtents1
type fieldExtents;
threshold 0.5;
internalField true;
referencePosition (0 0 0);
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: fieldExtents | word | yes | - |
| threshold | Value to identify extents boundary | scalar | yes | - |
| fields | List of operand fields | wordList | yes | - |
| internalField | Flag to process the internal field | bool | no | true |
| referencePosition | Reference position | vector | no | (0 0 0) |
| patches | List of patches to process | wordList | no | <all patches> |
For non-scalar fields, the magnitude of the field is employed and compared to the value of threshold.
