The fieldMinMax function object computes the values and locations of field minima and maxima. These are good indicators of calculation performance, e.g. to confirm that predicted results are within expected bounds, or how well a case is converging.
Multiple fields can be processed, where for rank > 0 primitives, e.g. vectors and tensors, the extrema can be calculated per component, or by magnitude. In addition, spatial location and local processor index are included in the output.
| input | - | - |
| output field | - | - |
Example of the fieldExtents function object by using functions sub-dictionary in system/controlDict file:
fieldMinMax1
type fieldMinMax;
mode magnitude;
location true;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: fieldExtents | word | yes | - |
| fields | List of operand fields | wordList | yes | - |
| location | Write location of the min/max value | bool | no | true |
| mode | Calculation mode: magnitude or component | word | no | magnitude |
Integral values are stored for further post-processing:
min(<fieldName>)min(<field>)_positionmin(<field>)_processormax(<field>)max(<field>)_positionmax(<field>)_processorTutorial:
