The fieldValueDelta function object computes a selected operation between two fieldValue function objects.
The operation is applied to all results of each fieldValue object. Accordingly, each object must generate the same number and type of results.
Example of the fieldValueDelta function object by using functions sub-dictionary in system/controlDict file:
fieldValueDelta1
type fieldValueDelta;
operation subtract;
region1
region2
writeFields false;
scalingFactor 1.0;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: fieldValueDelta | word | yes | - |
| operation | Operation type to apply to values | word | yes | - |
| region1 | Region1 properties | dict | yes | - |
| region2 | Region2 properties | dict | yes | - |
Options for the operation entry:
add | add subtract | subtract min | minimum max | maximum average | average
