The flux function object computes the flux of an input vector field.
| input | {vol,surface}VectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | surfaceScalarField | $FOAM_CASE/<time>/<outField> |
Example of the flux function object by using functions sub-dictionary in system/controlDict file:
flux1
type flux;
rho none;
field <field>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: flux | word | yes | - |
| rho | Name of density field | word | no | none |
