The grad function object computes the gradient of an input field.
The operation is limited to scalar and vector volume or surface fields, and the output is a volume vector or tensor field.
| input | {vol,surface}{Scalar,Vector}Field | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | vol{Vector,Tensor}Field | $FOAM_CASE/<time>/<outField> |
Example of the grad function object by using functions sub-dictionary in system/controlDict file:
grad1
type grad;
field <field>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: grad | word | yes | - |
postProcess -func "grad(<field>)"
