The heatTransferCoeff function object computes the heat transfer coefficient as a volScalarField for a set of patches.
| input | - | - |
| output file | - | - |
Example of the heatTransferCoeff function object by using functions sub-dictionary in system/controlDict file:
heatTransferCoeff1
type heatTransferCoeff;
field <field>;
patches (<patch1> <patch2> ... <patchN>);
htcModel <htcModel>;
UInf (20 0 0);
Cp CpInf;
CpInf 1000;
rho rhoInf;
rhoInf 1.2;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: heatTransferCoeff | word | yes | - |
| patches | Names of the operand patches | wordList | yes | - |
| htcModel | Model for coefficient computation | word | yes | - |
| UInf | Reference flow speed | scalar | yes | - |
| rho | Fluid density | scalar | yes | - |
postProcess -func "heatTransferCoeff(<field>)"
The following options are available for the htcModel entry:
ReynoldsAnalogy: Reynolds analogy
\[ h = 0.5 \rho_\infty C_{p,\infty} |U_{\infty}| C_f \]
localReferenceTemperature: local reference temperature
\[ h = \frac{q}{T_c - T_w} \]
fixedReferenceTemperature: fixed reference temperature
\[ h = \frac{q}{T_c - T_{ref}} \]
