The histogram function object computes the volume-weighted histogram of an input volScalarField.
| input | volScalarField | $FOAM_CASE/<time>/<inpField> |
| output field | - | - |
The set written contains two columns, the first the volume averaged values, the second the raw bin count.
Example of the histogram function object by using functions sub-dictionary in system/controlDict file:
histogram1
type histogram;
field p;
nBins 100;
setFormat gnuplot;
max 5;
min -5;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: histogram | word | yes | - |
| field | Name of operand field | word | yes | - |
| nBins | Number of histogram bins | label | yes | - |
| setFormat | Output format | word | yes | - |
| max | Maximum value sampled | scalar | no | fieldMax |
| min | minimum value sampled | scalar | no | 0.0 |
If max is not provided it will use the field's min and max as the bin extremes. If max is provided but not min, it will use 0.
