The interfaceHeight function object reports the height of the interface above a set of locations. For each location, it writes the vertical distance of the interface above both the location and the lowest boundary. It also writes the point on the interface from which these heights are computed. It uses an integral approach, so if there are multiple interfaces above or below a location then this method will generate average values.
| input | - | - |
| output file 1 | dat | $FOAM_CASE/postProcessing/<FO>/<time>/height |
| output file 2 | dat | $FOAM_CASE/postProcessing/<FO>/<time>/position |
| output field | - | - |
Example of the interfaceHeight function object by using functions sub-dictionary in system/controlDict file:
interfaceHeight1
type interfaceHeight;
locations ((0 0 0) (10 0 0) (20 0 0));
alpha alpha.water;
liquid true;
direction (1 0 0);
interpolationScheme cellPoint;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: interfaceHeight | word | yes | - |
| locations | Locations to report the height at | vectorList | yes | - |
| alpha | Name of alpha field | word | no | alpha |
| liquid | Flag if the alpha field that of the liquid | bool | no | true |
| direction | Direction of interface | vector | no | g |
| interpolationScheme | Interpolation scheme | word | no | cellPoint |
