The limitFields function object limits input fields to user-specified min and max bounds.
For non-scalar types of input fields, the user limit is used to create a scaling factor using the field magnitudes.
| output file | - | - |
Example of the limitFields function object by using functions sub-dictionary in system/controlDict file:
limitFields1
type limitFields;
fields (U);
limit max;
max 100;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: limitFields | word | yes | - |
| fields | List of fields to process | wordList | yes | - |
| limit | Bound to limit - see below | word | yes | - |
| min | Min limit value | scalar | conditional | - |
| max | Max limit value | scalar | conditional | - |
Options for the limit entry:
min | Specify a minimum valuemax | Specify a maximum valueboth | Specify a minimum value and a maximum valueThe inherited entries are elaborated in:
postProcess -func limitFields
