The mapFields function object maps input fields from local mesh to secondary mesh at runtime.
| output file | - | - |
Example of the mapFields function object by using functions sub-dictionary in system/controlDict file:
mapFields1
type mapFields;
mapRegion coarseMesh;
mapMethod cellVolumeWeight;
consistent true;
// patchMapMethod direct; // AMI-related entry
// enabled if consistent=false
// patchMap (<patchSrc> <patchTgt>);
// cuttingPatches (<patchTgt1> <patchTgt2> ... <patchTgtN>);
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: mapFields | word | yes | - |
| fields | Names of operand fields | wordList | yes | - |
| mapRegion | Name of region to map to | word | yes | - |
| mapMethod | Mapping method | word | yes | - |
| consistent | Mapping meshes have consistent boundaries | bool | yes | - |
| patchMapMethod | Patch mapping method for AMI cases | word | no | - |
| patchMap | Coincident source/target patches in two cases | wordHashTable | no | - |
| cuttingPatches | Target patches cutting the source domain | wordList | no | - |
Options for the mapMethod entry:
direct mapNearest cellVolumeWeight correctedCellVolumeWeight
Options for the patchMapMethod entry:
directAMI mapNearestAMI faceAreaWeightAMI partialFaceAreaWeightAMI
