The momentumError function object computes balance terms for the steady momentum equation.
| input | - | - |
| output file | - | - |
| output field | volVectorField | $FOAM_CASE/<time>/<file> |
Example of the momentumError function object by using functions sub-dictionary in system/controlDict file:
momentumError1
type momentumError;
p <pName>;
U <UName>;
phi <phiName>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: momentumError | word | yes | - |
| p | Name of pressure field | word | no | p |
| U | Name of velocity field | word | no | U |
| phi | Name of flux field | word | no | phi |
