The particleDistribution function object generates a particle distribution for lagrangian data at a given time.
| input | - | - |
| output field | - | - |
Example of the particleDistribution function object by using functions sub-dictionary in system/controlDict file:
particleDistribution1
type particleDistribution;
cloud <cloudName>;
nameVsBinWidth
(d 0.1)
(U 10)
setFormat raw;
tagField none;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: particleDistribution | word | yes | - |
| cloud | Name of cloud to process | word | yes | - |
| nameVsBinWidth | List of cloud field-bin width | wordHashTable | yes | - |
| setFormat | Output format | word | yes | - |
| tagField | Name of cloud field to use group particles | word | no | none |
