The pow function object computes the power of an input volScalarField.
\[ f = s f_0^n + t \]
where
| \( f \) | = | Output volScalarField |
| \( f_0 \) | = | Input volScalarField |
| \( n \) | = | Exponent |
| \( s \) | = | Scaling factor |
| \( t \) | = | Offset factor |
| input | volScalarField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the pow function object by using functions sub-dictionary in system/controlDict file:
pow1
type pow;
// Mandatory (inherited) entry (runtime modifiable)
field <inpField>;
checkDimensions false;
scale 1.0;
offset 0.0;
result <fieldResult>;
region region0;
pow true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: pow | word | yes | - |
| checkDimensions | Flag to check dimensions of the operand field | bool | no | true |
| scale | Scaling factor - s above | scalar | no | 1.0 |
| offset | Offset factor - t above | scalar | no | 0.0 |
postProcess -func "pow(<inpField>)" -scale 1.0 -offset 0.0
