The processorField function object writes a scalar field whose value is the local processor ID. The output field name is processorID.
| input | volScalarField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the processorField function object by using functions sub-dictionary in system/controlDict file:
processorField1
type processorField;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: processorField | word | yes | - |
postProcess -func processorField
