The proudmanAcousticPower function object computes the acoustic power due to the volume of isotropic turbulence using Proudman's formula.
The acoustic power, i.e. \(P_A\) [W/m^3] in terms of turbulent kinetic energy, i.e. \(k\), and turbulent kinetic energy dissipation rate, i.e. \(\epsilon\) is given as:
\[ P_A = \alpha_\epsilon \rho \epsilon M_t^5 \]
where \(\alpha_\epsilon = 0.1\) is a constant and
\[ M_t = \frac{\sqrt{2 k}}{a_0} \]
with \(a_0\) the speed of sound.
The acoustic power is also output in dB using:
\[ L_P = 10 \log \frac{P_A}{P_{ref}} \]
where \(P_{ref} = 1e^{-12}\) [W/m^3] is a constant.
| input | volScalarField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the proudmanAcousticPower function object by using functions sub-dictionary in system/controlDict file:
proudmanAcousticPower1
type proudmanAcousticPower;
alphaEps 0.1;
// For incompressible flow simulations
rhoInf 1.225;
aRef 340;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: proudmanAcousticPower | word | yes | - |
| rhoInf | Freestream density (for incompressible) | scalar | conditional | - |
| aRef | Speed of sound (incompressible) | scalar | conditional | - |
| alphaEps | Empirical model coefficient | scalar | no | 0.1 |
The freestream density and reference speed of sound are only necessary when a thermodynamics package is unavailable, typically for incompressible cases.
