The randomise function object adds a random component to an input field, with a specified perturbation magnitude.
| output file | - | - |
Example of the randomise function object by using functions sub-dictionary in system/controlDict file:
randomise1
type randomise;
magPerturbation 0.1;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: randomise | word | yes | - |
| magPerturbation | The magnitude of the perturbation | scalar | yes | - |
postProcess -func "randomise(<field>)"
