The reactionsSensitivityAnalysis function object computes indicators for reaction rates of creation or destruction of species in each reaction.
This function object creates four data files named:
"consumption" : consumption rate "production" : destruction rate "productionInt" : integral between dumps of the production rate "consumptionInt" : integral between dumps of the consumption rate
| input | - | - |
| output field | - | - |
Example of the reactionsSensitivityAnalysis function object by using functions sub-dictionary in system/controlDict file:
reactionsSensitivityAnalysis1
type reactionsSensitivityAnalysis;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: reactionsSensitivityAnalysis | word | yes | - |
chemistryModel chosen.Source code:
