The readFields function object reads fields from the time directories and adds them to the mesh database for further post-processing.
| output file | - | - |
| output field | vol<Type>Field | Mesh database |
Example of the readFields function object by using functions sub-dictionary in system/controlDict file:
readFields1
type readFields;
readOnStart true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: readFields | word | yes | - |
| fields | Names of the operand fields | wordList | yes | - |
| readOnStart | Flag to start reading on start-up | bool | no | true |
