The regionSizeDistribution function object creates a droplet size distribution via interrogating a continuous phase fraction field.
Looks up a phase-fraction (alpha) field and splits the mesh into regions based on where the field is below the threshold value. These regions ("droplets") can now be analysed.
Regions:
volScalarFieldOutput (volume scalar) fields include:
Histogram:
minDiameter, maxDiameter, nBins)volVectorFields these are those of the 3 components and the magnitude.origin, direction and maxDiameter up to maxDownstream| Operand | Type | Location |
| input | - | - |
| output file | - | $FOAM_CASE/postProcessing/<FO>/<time>/<files> |
| output field | - | - |
Example of the regionSizeDistribution function object by using functions sub-dictionary in system/controlDict file:
regionSizeDistribution1
type regionSizeDistribution;
field alpha;
patches (inlet);
fields (p U);
threshold 0.4;
maxDiameter 5e-5;
nBins 100;
setFormat gnuplot;
minDiameter 0.0;
coordinateSystem
origin (0 0 0);
rotation
type axes;
e3 (0 0 1);
e1 (1 0 0);
// Optional downstream iso-plane bins
isoPlanes true;
// Mandatory entries if isoPlanes=true (runtime modifiable)
// Plane normal and point definition
origin (1e-4 0 5e-4);
direction (1 0 1);
// Maximum diameter of the cylinder formed by the origin point
// and direction
maxD 3e-4;
// Maximum downstream distance
maxDownstream 6e-4;
// Number of iso-plane bins
nDownstreamBins 20;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: regionSizeDistribution | word | yes | - |
| field | Phase field to interrogate | word | yes | - |
| patches | Patches wherefrom the liquid core is identified | wordList | yes | - |
| fields | Fields to sample | wordList | yes | - |
| threshold | Phase fraction applied to delimit regions | scalar | yes | - |
| maxDiameter | Maximum droplet diameter | scalar | yes | - |
| minDiameter | Minimum droplet diameter | scalar | no | 0.0 |
| nBins | Number of bins for histogram | label | yes | - |
| setFormat | Output format | word | yes | - |
| isoPlanes | Flag for isoPlanes | bool | no | false |
| origin | Origin of the plane when isoPlanes is used | vector | yes | - |
| direction | Direction of the plane when isoPlanes is used | vector | yes | - |
| maxD | Maximum diameter of the sampling cylinder when isoPlanes is used | vector | yes | - |
| nDownstreamBins | Number of bins when isoPlanes is used | label | yes | - |
| maxDownstream | Maximum distance from origin when isoPlanes is used | scalar | yes | - |
