The setFlow function object provides options to set the velocity and flux fields as a function of time.
Useful for testing advection behaviour of numerical schemes by e.g. imposing solid body rotation, vortex flows. All types include a scaling Foam::Function1 type enabling the strength of the transformation to vary as a function of time.
| input | {vol,surface}<Type>Field | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | {vol,surface}<Type>Field | $FOAM_CASE/<time>/<outField> |
Example of the setFlow function object by using functions sub-dictionary in system/controlDict file:
setFlow1
type setFlow;
mode rotation;
scale 1;
U U;
rho none;
phi phi;
reverseTime 1;
// When mode=function
velocity (1 0 0);
// When mode=rotation
omega 6.28318530718;
origin (0.5 0 0.5);
refDir (1 0 0);
axis (0 1 0);
// When mode=(vortex2D|vortex3D)
origin (0.5 0 0.5);
refDir (1 0 0);
axis (0 1 0);
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: setFlow | word | yes | - |
| mode | Operating mode - see below | word | yes | - |
| scale | Scaling function | Function1<scalar> | yes | - |
| U | Name of velocity field | word | no | U |
| rho | Name of density field | word | no | none |
| phi | Name of flux field | word | no | phi |
| reverseTime | Specified time to reverse flow direction | scalar | no | VGREAT |
| velocity | Velocity function | Function1<vector> | conditional | - |
| omega | Rotational speed function | Function1<scalar> | conditional | - |
| origin | Rotation vector origin | vector | conditional | - |
| refDir | Rotation vector reference direction | vector | conditional | - |
| axis | Rotation vector axis | vector | conditional | - |
Options for the mode entry:
function rotation vortex2D vortex3D
