The streamFunction function object computes the stream function (i.e. https://w.wiki/Ncm).
| input | surfaceScalarField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | pointScalarField | $FOAM_CASE/<time>/<outField> |
Example of the streamFunction function object by using functions sub-dictionary in system/controlDict file:
streamFunction1
type streamFunction;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: streamFunction | word | yes | - |
postProcess -func streamFunction
