The streamLine function object generates streamline data by sampling a set of user-specified fields along a particle track, transported by a user-specified velocity field.
| input | - | - |
| output file | - | $FOAM_CASE/postProcessing/sets/<FO>/<time>/<file> |
| output field | - | - |
Example of the streamLine function object by using functions sub-dictionary in system/controlDict file:
streamLine1
type streamLine;
U <fieldTrack>;
fields (<fieldTrack> <field1> ... <fieldN>);
setFormat vtk;
direction bidirectional;
lifeTime 10000;
cloud particleTracks;
seedSampleSet
type uniform;
axis x;
start (-0.0205 0.0001 0.00001);
end (-0.0205 0.0005 0.00001);
nPoints 100;
bounds (0.2 -10 -10)(0.22 10 10);
trackLength 1e-3;
nSubCycle 1;
interpolationScheme cellPoint;
// Deprecated
// trackForward true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: streamLine | word | yes | - |
| U | Name of tracking velocity field | word | yes | - |
| fields | Names of operand fields to sample | wordList | yes | - |
| setFormat | Type of output data | word | yes | - |
| direction | Direction to track | vector | yes | - |
| lifetime | Maximum number of particle tracking steps | label | yes | - |
| cloud | Name of cloud | word | yes | - |
| seedSampleSet | Name of seeding method (see below) | word | yes | - |
| bounds | Bounding box to trim tracks | vector | no | invertedBox |
| trackLength | Tracking segment length | scalar | no | VGREAT |
| nSubCycle | Number of tracking steps per cell | label | no | 1 |
| interpolationScheme | Interp. scheme for sample | word | no | cellPoint |
Options for the seedSampleSet entry:
uniform | uniform particle seeding cloud | cloud of points triSurfaceMeshPointSet | points according to a tri-surface mesh
Options for the setFormat entry:
csv ensight gnuplot jplot nastran raw vtk xmgr
Options for the direction entry:
bidirectional forward backward
trackLength or nSubCycle option should be used.Tutorial:
