The surfaceDistance function object computes the distance to the nearest surface from a given geometry.
| input | - | - |
| output file | - | - |
| output field | volScalarField | $FOAM_CASE/<time>/surfaceDistance |
Example of the surfaceDistance function object by using functions sub-dictionary in system/controlDict file:
surfaceDistance1
type surfaceDistance;
geometry
motorBike.obj
type triSurfaceMesh;
name motorBike;
calculateCells true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: surfaceDistance | word | yes | - |
| geometry | Surface details | dict | yes | - |
| calculateCells | Calculate distance from cell | bool | no | true |
