The surfaceInterpolate function object linearly interpolates volume fields to generate surface fields.
| output file | - | - |
| output field | surface<Type>Field | $FOAM_CASE/<time>/<outField> |
Example of the surfaceInterpolate function object by using functions sub-dictionary in system/controlDict file:
surfaceInterpolate1
type surfaceInterpolate;
fields ((<inpField1> <outField1>) ... (<inpFieldN> <outFieldN>));
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: surfaceInterpolate | word | yes | - |
| fields | Names of operand and output fields | wordList | yes | - |
