The turbulenceFields function object computes various turbulence-related quantities that are not typically output during calculations, including:
k: Turbulent kinetic energyepsilon: Turbulent kinetic energyu dissipation rateomega: Specific dissipation rateR: Reynolds stress tensorL: Integral-length/Mixing-length scaleI: Turbulence intensitynuTilda: Modified turbulent viscosityAdditional field selections for incompressible cases:
nut: Turbulent (edy) kinematic viscositynuEff: Effective kinematic viscosity (laminar + turbulent contributions)devReff: Deviatoric stress tensorAdditional field selections for compressible cases:
mut: Turbulent (eddy) dynamic viscositymuEff: Effective dynamic viscosity (laminar + turbulent contributions)alphat: Thermal eddy diffusivityalphaEff: Effective eddy thermal diffusivitydevRhoReff: Deviatoric stress tensorThese fields are stored on the mesh database for further post-processing, and written as regular volume fields at write intervals.
| input | - | - |
| output file | - | - |
Example of the turbulenceFields function object by using functions sub-dictionary in system/controlDict file:
turbulenceFields1
type turbulenceFields;
// Either field or fields entries
fields (R devRhoReff);
field R;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: turbulenceFields | word | yes | - |
| fields | Names of fields to store (see below) | wordList | yes | - |
| field | Name of a field to store (see below) | word | yes | - |
<solver> -postProcess -func turbulenceFields
Fields stored on the mesh database with the prefix turbulenceProperties:, e.g.
turbulenceProperties:mut turbulenceProperties:R turbulenceProperties:devRhoReff
and written to the standard time directories according to the writeControl setting.
