The wallHeatFlux function object computes the wall-heat flux at selected wall patches.
| input | - | - |
| output file | dat | $FOAM_CASE/postProcessing/<FO>/<time>/<field> |
| output field | volScalarField (only boundaryField) | $FOAM_CASE/<time>/<outField> |
Example of the wallHeatFlux function object by using functions sub-dictionary in system/controlDict file:
wallHeatFlux1
type wallHeatFlux;
patches (<patch1> ... <patchN>); // (wall1 "(wall2|wall3)");
qr qr;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: wallHeatFlux | word | yes | - |
| patches | Names of operand patches | wordList | no | all wall patches |
| qr | Name of radiative heat flux field | word | no | qr |
<solver> -postProcess -func wallHeatFlux
