The wallShearStress function object computes the wall-shear stress at selected wall patches.
\[ \vec \tau = \vec R \cdot \vec n \]
where
| \( \vec \tau \) | = | Wall shear stress vector [m2/s2] |
| \( \vec R \) | = | Shear-stress symmetric tensor (retrieved from turbulence model) |
| \( \vec n \) | = | Patch normal vector (into the domain) |
| input | - | - |
| output file | dat | $FOAM_CASE/postProcessing/<FO>/<time>/<field> |
| output field | volVectorField (only boundaryField) | $FOAM_CASE/<time>/<outField> |
Example of the wallShearStress function object by using functions sub-dictionary in system/controlDict file:
wallShearStress1
type wallShearStress;
patches (<patch1> ... <patchN>); // (wall1 "(wall2|wall3)");
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: wallShearStress | word | yes | - |
| patches | Names of operand patches | wordList | no | all wall patches |
<solver> -postProcess -func wallShearStress
