The writeCellCentres function object writes the cell-centres volVectorField and the three component fields as volScalarFields.
| input | - | - |
| output file | - | - |
| output field 1 | volVectorField | $FOAM_CASE/<time>/C |
| output field 2 | volScalarField | $FOAM_CASE/<time>/{Cx,Cy,Cz} |
Example of the writeCellCentres function object by using functions sub-dictionary in system/controlDict file:
writeCellCentres1
type writeCellCentres;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: writeCellCentres | word | yes | - |
postProcess -func writeCellCentres
