The writeCellVolumes function object writes the cell-volumes volScalarField.
| input | - | - |
| output file | - | - |
| output field | volScalarField | $FOAM_CASE/<time>/V |
Example of the writeCellVolumes function object by using functions sub-dictionary in system/controlDict file:
writeCellVolumes1
type writeCellVolumes;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: writeCellVolumes | word | yes | - |
postProcess -func writeCellVolumes
