The yPlus function object computes the near wall \(y_1^+\) for turbulence models.
| input | - | - |
Example of the yPlus function object by using functions sub-dictionary in system/controlDict file:
yPlus1
type yPlus;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: yPlus | word | yes | - |
<solver> -postProcess -func yPlus
channel395DFSEM tutorial: $FOAM_TUTORIALS/incompressible/pimpleFoam/LES/channel395DFSEMSource code:
