The zeroGradient function object creates a volume field with zero-gradient boundary conditions from another volume field.
The result can be used, for example, to post-process near-wall field values.
| output file | - | - |
Example of the zeroGradient function object by using functions sub-dictionary in system/controlDict file:
zeroGradient1
type zeroGradient;
fields (<field1> ... <fieldN>); \\(U "(T|k|epsilon|omega)");
result @@<name>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: zeroGradient | word | yes | - |
| fields | Name of the operand fields | wordList | yes | - |
| result | Name of the output field | word | no | zeroGradient(@) |
A list of fields can contain exact names or regular expressions. The token '@@' in the result name is replaced by the name of the source field. In the special case of a single source field (specified as a non-regex), the '@@' token checking is suppressed.
The function object will skip over fields that would not benefit
processor, empty, zeroGradient, symmetry patches. This check should also prevent processing fields multiple times.Tutorial:
