The runTimePostProcessing function object generates images by assembling and compositing scene objects, typically produced via function objects.
The runTimePostProcessing function object is specified using multiple sub-dictionaries that describe the desired output, camera and scene object settings:
runTimePostPro1
type runTimePostProcessing;
libs ("librunTimePostProcessing.so");
// Image properties
output
// Visualisation properties
camera
// Default colours
colours
// Scene objects
lines
surfaces
text
The output sub-dictionary describes properties of the output png file
output
name image;
width 2000;
height 1200;
Basic operation of a static camera comprises:
camera
// Parallel projection flag
parallelProjection no;
// Camera geometry
focalPoint (1.2 1.1 0.2);
up (0 0 1);
position (3.6 5.1 -1.3);
// Optional properties
// Restrict the view to a clip box
clipBox (-0.2 -0.2 0)(1.65 0.2 1.25);
Optionally, the camera can move. Each of the camera geometry controls is a Foam::Function1 type, and can be set to vary as a function of scene time using e.g. tabulated, polynomial, sinusoidal profiles etc. The scene time is defined as a linear function between zero and one.
An example using tabulated entries is given by:
camera
// Camera geometry
up (0 0 1);
// If camera is moving, optionally provide start and end times
// Note: specified in scene time in range 0-1
startPosition 0.2;
endPosition 0.75;
// Total number of frames to generate
nFrameTotal 20;
The colours sub-dictionary defines the set of default colours to employ for the background, and scene objects when the colourBy entry is set to colour.
colours
background (1 1 1);
text (0 0 0);
edge (1 0 0);
surface (0.5 0.5 0.5);
line (1 0 0);
// Optional
// Set a second background colour to produce a graded background
background2 (0 0 1);
Scene objects provide the main focus of the image, e.g. lines, surfaces and text. All objects have a visible property to optionally hide the object.
The lines sub-dictionary describes line-based data, e.g. the output from stream lines. Valid line types include:
functionObjectLine: line based data produced by a function object lines
streamline
type functionObjectLine;
functionObject streamLines;
representation tube;
visible yes;
tubeRadius 0.01;
colourBy field;
field U;
range (0 20);
opacity 1;
Related:
Example usage:
motorBike tutorial: $FOAM_TUTORIALS/incompressible/pisoFoam/LES/motorBike/motorBikeHistory
Copyright © 2016 OpenCFD Ltd.
