blockMesh is a structured hexahedral mesh generator.
Key features:
Constraints:
Well suited to simple geometries that can be described by a few blocks, but challenging to apply to cases with a large number of blocks due to book-keeping requirements, i.e. the need to manage point connectivity and ordering.
The utility is controlled using a blockMeshDict dictionary, located in the case system directory, split into the following sections:
Example usage:
Copyright © 2017-2019 OpenCFD Ltd.
