A topoSetPointSource to select all the points from given cellSet(s).
| input | cellSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the cellToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source cellToPoint;
option <option>;
// Select either of the below
// Option-1
sets
<pointSetName1>
<pointSetName2>
// Option-2
set <pointSetName>;
| source | Source name: cellToPoint | word | yes | - |
Options for the action entry:
Options for the option entry:
all | Select all points of cells in the cellSet
Entry | Description | Type | Required | Default sets | Names of input pointSets | wordList | conditional | - set | Name of input pointSet | word | conditional | -
Copyright © 2020 OpenCFD Ltd.
