A topoSetPointSource to select all points based on usage in given faceSet(s).
| input | faceSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the faceToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source faceToPoint;
option <option>;
// Select either of the below
// Option-1
sets
<faceSetName0>
<faceSetName1>
// Option-2
set <faceSetName>;
| source | Source name: faceToPoint | word | yes | - |
| option | Selection type - see below | word | yes | - |
Options for the action entry:
Options for the option entry:
all | Select all points of faces in the faceSet
Entry | Description | Type | Required | Default sets | Names of input faceSets | wordList | conditional | - set | Name of input faceSet | word | conditional | -
Copyright © 2020 OpenCFD Ltd.
