A topoSetPointSource to select points based on explicitly given point labels.
Example of the labelToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source labelToPoint;
value
<cellLabel1>
<cellLabel2>
| source | Source name: labelToPoint | word | yes | - |
| value | Input cell labels | labelList | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
