A topoSetPointSource to select points which are inside a given bounding sphere.
Example of the sphereToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source sphereToPoint;
origin (0 0 0);
radius 0.5;
// Optional entries
innerRadius 0;
| source | Source name: sphereToPoint | word | yes | - |
| origin | The origin (centre) of the sphere | vector | yes | - |
| radius | The (outer) radius of sphere | scalar | yes | - |
| innerRadius | The inner radius of sphere | scalar | no | 0 |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
