A topoSetPointSource to select points based on relation to a surface given by an external file.
surfaceToPoint can select based on:
| input | typical surface file format (e.g. STL) | $FOAM_CASE/<file> |
Example of the surfaceToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source surfaceToPoint;
file <surfaceFileName>;
includeInside false;
includeOutside true;
nearDistance 0.5;
// Optional entries
fileType stl;
scale 2.0;
| source | Source name: surfaceToPoint | word | yes | - |
| file | The surface "filename" | word | yes | - |
| includeInside | Flag to include inside points | bool | yes | - |
| includeOutside | Flag to include outside points | bool | yes | - |
| nearDistance | Near distance to the surface | scalar | yes | - |
| fileType | The format of the surface file | word | no | "" |
| scale | Surface scaling factor | scalar | no | -1 |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
