A topoSetPointSource to convert pointZone(s) to a pointSet.
| input | pointZone(s) | $FOAM_CASE/constant/polyMesh/pointZones |
Example of the zoneToPoint topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source zoneToPoint;
// Select either of the below
// Option-1
zones
<pointZoneName0>
<pointZoneName1>
// Option-2
zone <pointZoneName>;
| source | Source name: zoneToPoint | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default zones | Names of input pointZones | wordList | conditional | - zone | Name of input pointZone | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is zones, and zone.
Copyright © 2020 OpenCFD Ltd.
