A topoSetSource to convert a pointSet to a pointZone (and associated pointSet).
| input | pointSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 1 | pointSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 2 | pointZone | $FOAM_CASE/constant/polyMesh/pointZones |
Example of the setToPointZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type pointSet;
action <action>;
// Mandatory entries
source setToPointZone;
set <pointSetName>;
| source | Source name: setToPointZone | word | yes | - |
| set | Name of input pointSet | word | yes | - |
Options for the action entry:
new | Create a new pointZone from selected points of a pointSet add | Add selected points of a pointSet into this pointZone subtract | Remove selected points of a pointSet from this pointZone
Copyright © 2020 OpenCFD Ltd.
