The Expressions syntax enables users to define custom expressions for use in a variety of scenarios, including:
The following sections describe how to write the expressions and provide an overview of the range of functionality.
The term expressions implies the interpretation of string-like input as various types of mathematical or field evaluations within OpenFOAM itself. For example, to use the following string input in a dictionary as a mathematical evaluation (after substitution of the dictionary variables):
Alternatively, to use the following string input to define a volume-field evaluation:
The expressions do not use dynamically compiled C++-code to solve the problem, but instead rely upon predefined grammar rules and parsing operations for the evaluation. The entire evaluation is called a parse or parser operation, although it strictly speaking comprises three components:
For most purposes the distinction between the sub-components can be safely ignored and the entirety simply called the parser.
However, as the first examples illustrate, a parser is domain-specific and there will be different types of parsers for different applications. Currently these are the following:
fieldExpr : a general mathematical and field expression parser for primitive fields such as scalarField, vectorField, but not associated with any geometric fields or mesh geometry. For a field size of 1 this corresponds to a mathematical (non-field) expression evaluation.patchExpr : expression evaluation on patches. Use face values for its native structure, with the possibility of accessing point values.The basic syntax of the expressions largely resembles that of the OpenFOAM source code:
sqrt(), mag(), magSqr() wherever possible.Since expressions may easily grow in complexity, internal documentation of expressions is encouraged in the form of C/C++ style comments internal to the expression. For example,
There is no support for macros, but since the expression is generally passed through dictionary expansion prior to evaluation, dictionary substitutions can be used. For example,
More advanced information about macro or dictionary substitutions is provided in later sections.
The usual precedence-rules apply:
+ - * / : Arithmetic operations& : Inner product for vectors and tensors^ : Cross product of two vectors% : Modulo operator&& || : The logical and and or operators- : Unary negation! : Logical negation< > >= <= : Relational comparisons== != : : Equality and inequality-operators? and : : Ternary operator for cond ? a : b. The condition must evaluate to bool, the fields a and b must be of the same type.When field or variable names are referenced, the identifiers are similar to C++ requirements (alphanumeric with underscores) but the dot (.) character is also permitted when it does not appear at the start of the name.
General punctuation-like characters that are occasionally used in OpenFOAM fields, e.g. the - or : characters, cannot be used directly as identifiers, but require quoting of the entire identifier.
Single/double quotes are used to support arbitrary characters in an identifier. For example, "sin(angle)" and "field:a-b" would be treated as single identifiers, even if they would otherwise appear to be expressions.
Note that there is no semantic difference between single and double quotes, but they must be used consistently for quoting an individual element, i.e.,
The expressions support the familiar OpenFOAM data types:
volumeExpr an internal representation as scalar (0,1) may be used.Since operations with fields of integers are not intrinsic to OpenFOAM, they are not supported in expressions either; here scalar types should be used instead. If incompatible operations are specified within an expression the parser will issue an error message during the evaluation. Examples of incompatible operations:
For example,
The syntax error only appears after the vector composition has finalized and the parser determines that the parameter for sqrt is not valid. Users may initially find the location of the error slightly odd and/or difficult to interpret, but a second valid example helps illustrate why this error location was correct:
Here the expressions continues on with a dot-product & followed by another vector composition. The parser can now continue and reduces this to a scalar, which is a valid parameter for sqrt.
The return type of the expression result is a polymorphic data type, which means that its type is only known after the evaluation has completed. If this does not match the expected type, it will generate a runtime error only after the expression has been evaluated.
Numeric constants are written in regular C++/OpenFOAM forms. For example, 42, 3.1415, 6.66e2 etc. However, just like with OpenFOAM dictionary syntax, numbers with a leading positive sign are not supported. So 42.0 and -42.0 are valid, but +42.0 is not.
Named constants resemble functions:
pi() : 3.14159...degToRad() : same as pi() / 180 but as a pre-calculated valueradToDeg() : same as 180 / pi() but as a pre-calculated valuetime() : the current simulation time-value (if used by the parser)This form makes it easier to reuse constants as unary functions. For example, the function degToRad() can be used with or without arguments such that both sin(degToRad(45)) and sin(45*degToRad()) will produce the expected result.
There are a few literals used as contants as well:
true, false : for boolean valuestensor::I : is the unit tensorZero : equivalent to the Foam::zero constantAs previously mentioned, expressions can handle different data types, but unlike C++ code we lack regular means of declaring the types. Instead a composition syntax is used to define all non-scalar types.
Vector values can be constructed using the keyword vector and three scalar values or scalar fields. These scalars can be constants or sub-expressions that yield scalars. For example,
Tensors are constructed with the keyword tensor and 9 scalar values for the components.
Symmetric tensors are constructed using the keyword symmTensor and 6 components (xx, xy, xz, yy, yz, zz).
Spherical tensors are constructed using sphericalTensor and a single scalar component.
Boolean fields are somewhat special since they are normally the result of some logical operation and are not defined directly. However, the keyword bool can be used to force a boolean conversion of scalar values. A threshold of -/+ 0.5 is used to define true/false. This definition is generous but works well under the assumption that scalars values (0,1) correspond to the truth values and allows for any rounding or interpolation effects. This also yields good characteristics when integer calculations have been performed with scalars. Some examples,
For some cases the bool keyword can makes expressions a bit easier to understand. For example,
versus
It is also possible to extract sub-components from more complex data types with component . methods. For example, the expression U.x() returns the X-component of the U field.
| Input Data Type | Component methods | Output data type |
| vector | x y z | scalar |
| tensor | xx xy xz yx yy yz zx zy zz | scalar |
| symmTensor | xx xy xz yy yz zz | scalar |
| sphericalTensor | ii | scalar |
The same . method syntax is used for tensor transpose, or extracting of vectors from tensors:
| tensor | x y z | vector (the corresponding rows) |
| tensor | diag | vector (the diagonal) |
| tensor | T | tensor (transpose) |
| symmTensor | diag | vector (the diagonal) |
| symmTensor | T | symmTensor (transpose is a no-op) |
| sphericalTensor | T | sphericalTensor (transpose is a no-op) |
Since a dot (.) can appear in a variable name, some ambiguity in the intended meaning of the input can arise. For example, the text U.x could be the field U.x, but potentially could also be leading into the expression U.x() - ie, the x-component of the U field.
The parser heuristics resolves this with the following approach:
U.x).x, xy, but not air) and attempt to resolve with the shortened field name (Eg, U).This approach masters most the fields from most simulations without any problem. It is fairly rare that a simulation would have both a U vector field and a U.x scalar field. If however such a situation does arise, it is simple to resolve with some direction from the user:
U .x() or (U).x()"U.x", ‘'U.x’or even"U".x()`Many typical OpenFOAM mathematical functions are implemented:
|x| Implemented for all data types. Yields a scalar. Can be also be used to convert a bool to a scalar.|x|^2 Implemented for all non-logical data types. Yields a scalarThe following functions only work for scalars:
x^ye^xsqrt(x^2, y^2)x^2sqrt(x)cbrt(x)floor(x)ceil(x)ceil(x)These functions depend on the sign of a scalar:
x greater zero: 1.0 else 0.0x greater-equal zero: 1.0 else 0.0x less zero: 1.0 else 0.0x less-equal zero: 1.0 else 0.0x is positive: 1.0 else if x is negative: -1.0These functions act as global reduction operations and return a single value across all processors:
The binary forms of min(x,y) and max(x,y) process and return fields.
There is also some support for random numbers.
rand() but using the integer value NUM for its seed.When the parser is associated with a mesh, the current time index is added to the seed so that the random distribution is different at each time-step but still reproducible.
The supported syntax described thus far as been general and common to all parsers. However, there are different expression parsers depending on where they can be applied. The function vol(), for example, is only appropriate for a volume-domain parser where a cell volume is actually meaningful.
To aid with keeping track of the capabilities, we assign some keys to the domains:
| Key | Name | Description |
| X | fieldExpr | general purpose, such as used in dictionary #eval expressions. |
| P | patchExpr | expression evaluation on patches |
| V | volumeExpr | expression evaluation on mesh internal/***volume*** |
It also also useful to reiterate an earlier point about the domain-specific parsers. These will have a natural or native structure used for field access, and may have secondary field types. This means that function such as pos() for mesh positions will mean different things in different domains. For a patch parser this corresponds to face centres, for a volume parser this corresponds to cell centres.
patchExpr : Uses faces for its native structure with points for its secondary structure.volumeExpr : Uses cells for its native structure, with surfaces or points for its secondary structure.Functions that provide information about the mesh and are used without any arguments:
| Function | Domain(s) | Description |
pos() | P, V | Native positions (P: face centres, V: cell centres) |
pts() | P, V | Point positions (P: face points, V: mesh points) |
fpos() | V | The face centres |
area() | P, V | The face area magnitudes |
face() | P, V | The face areaNormal vectors |
vol() | V | The cell volumes |
These functions are only available for the volume parser. They return a boolean field that identifies which cells/faces/points belong to the corresponding set or zone.
cset(NAME) | V | Logical volume field corresponding to cellSet |
fset(NAME) | V | Logical surface field corresponding to faceSet |
pset(NAME) | V | Logical point field corresponding to pointSet |
czone(NAME) | V | Logical volume field corresponding to cellZone |
fzone(NAME) | V | Logical surface field corresponding to faceZone |
pzone(NAME) | V | Logical point field corresponding to pointZone |
These functions incorporate domain-specific information.
weightAverage(..) | P, V | Area or volume weighted average (global) |
weightSum(..) | P, V | Area or volume weighted sum (global) |
The weighted functions select the correct weighting according to the context (volume or area). If given a point field, they revert to simple, unweighted versions of average or sum.
The functions support changing or interpolating between the native domain structure and the secondary structures. For example, in the volume parser, a plain number (eg, 42) or a constant (eg, true) is taken as a volume quantity. However, we may wish to have that constant value interpreted as a face or point value instead.
face(..) | V | A surface-field face value |
point(..) | P, V | A point-field point value |
Additionally, we can change (interpolate) between structures.
faceToPoint(..) | P | Interpolate face values onto points |
pointToFace(..) | P | Interpolate point values onto faces |
cellToFace(..) | V | Interpolate cell values onto faces |
cellToPoint(..) | V | Interpolate cell values onto points |
pointToCell(..) | V | Interpolate point values onto cells |
reconstruct(..) | V | Reconstruct cell vector from surface scalar |
An essential point for domain-specific parsers is how OpenFOAM fields are accessed.
Any identifier that is not a function defined in the grammar is taken to be the name of an internal variable (searched first) or an OpenFOAM field (searched second). The only exception to this rule is for sets/zones. The parser takes note when cset(..), fzone(..) etc functions have been seen and ensures that the following identifier is interpreted appropriately (as the name of the set/zone).
Since variables are searched for first, they can inadvertent shadow field names (eg, a variable called "rho" that effectively hides the OpenFOAM "rho" field). By default these will be detected and flagged as an error.
Registered fields are found via objectRegistry lookup. For some utilities, a mechanism similar to IOobjectList is used to locate these fields on disk.
With this knowledge we can understand how the following (volume) expression would be seen by the parser
pos(..) is the unary function for greater-than 0. Operates on a scalar.U.x appears to be a variable or field. But since U.x does not exist, backtracking finds that it can resolve this as a U field followed by a .x for the scalar component access. The following () pair completes the operation and the X-component of U is extracted.pos(..) now completes and yields a 0/1 scalar field for the X-component of U.pos() is without an argument, which returns the cell centres, to be multiplied by the previous scalar field.The term variables in the context of expressions denotes intermediate values that are accessible by name and normally stored in memory within the scope of the current domain parser. In some cases, variables may be unnecessary and dictionary substitution combined with inline evaluation suffices. In other cases, internally managed variables can provide better functionality and data encapsulation. We limit the description to regular variables only.
Variables are specified by the optional dictionary entry variables. The entry is a list of strings, of the following form:
These specify that the results of the expressions be saved with the respective names. The evaluation of the expressions uses the current parser and the entire field is saved for further use.
The variables are evaluated in the order of appearance and can be reused within the list (allows for intermediate variables). Once defined, there is no mechanism to undefine a variable.
It is also possible to define a variable within the current context based on an evaluation from a different domain parser or context. This is triggered by the presence of a {} qualifier for the variable name:
This means that expression is evaluated with the parser specified between {}. The form shown above is the most general.
The value of parser is one of the defined domain parsers (patch or volume). The name selects the concrete entity the parser should work on (for instance the patch name). Since patch references are the most common, this can be omitted and the specification of the patch name alone is sufficient:
which evaluates the expression on patch patchName.
In general, these external expressions are only meaningful when the the expression yields a uniform value (eg, a sum or average) since there is no other reasonable means to map or interpolate values from different types of entities, or entities with different sizes or locations. So if the expression yields a non-uniform value, a warning will be emitted and the average used.
Here is a further example of variable definitions:
The additional internal quoting is for illustrative purposes.
When used within expressions, the variable names are used without the qualifiers used in their declaration. For example,
Where p is the pressure field and pInlet is the variable previously defined as the average pressure at the inlet patch.
Before expression and variable strings are used, they are expanded in two different ways:
$[(cast)...] content.For example, given the following dictionary entry:
a regular dictionary substitution:
produces an expression that cannot be parsed:
To obtain the desired expansion, we resort to using the special expansion with a casting operation:
which produces an expression that can be parsed:
The additional embedded (vector) cast introduce the necessary vector composition keyword and also ensured that the vector components are separated with commas instead of spaces.
One additional remaining macro pasting is the #spec; handling while reading variable lists.
If a variable list element contains #spec; then that is searched for in the dictionary, interpreted as a variable list and inserted into the variable list. During this process other lists are recursively inserted and $ macros are expanded.
The Expressions functionality is a re-implementation of swak4Foam code and ideas, created by Bernhard Gschaider. Many thanks to him for many fruitful discussions leading to the release of the current functionality.
Copyright © 2019-2020 OpenCFD Ltd.
