For cases that the hydrostatic pressure contribution
\[ \rho ( \vec{g} \dprod \vec{h} ) \]
is important, e.g. for buoyant and multiphase cases, it is numerically convenient to solve for an alternative pressure defined by
\[ p' = p - \rho ( \vec{g} \dprod \vec{h} ). \]
In OpenFOAM solver applications the \(p'\) pressure term is named p_rgh. The momentum equation
\[ \ddt{\rho \u} + \div ( \rho \u \otimes \u ) - \div ( \mu_{\eff} \grad \u ) = - \grad p + \rho \vec{g} \]
is transformed to use \(p'\):
After the following substititions:
\[ \begin{align} - p & = - p' - \rho ( \vec{g} \dprod \vec{h} ) \\ - \grad p & = - \grad( p') - \grad ( \rho ( \vec{g} \dprod \vec{h} ) ) \\ & = - \grad( p') - \rho \vec{g} \dprod \grad \vec{h} - \vec{h} \dprod \grad(\rho \vec{g}) \\ & = - \grad( p') - \rho \vec{g} \dprod \tensor{I} - \vec{g} \dprod \vec{h} \grad (\rho) - \cancelto{0}{\rho \vec{h} \dprod \grad (\vec{g})} \\ & = - \grad( p') - \rho \vec{g} - \vec{g} \dprod \vec{h} \grad \rho \end{align} \]
where, for CFD meshes the term \( \grad \vec{h} \) is given by the gradient of the cell centres, which equates to the tensor \(\tensor{I}\), the momentum equation becomes:
\[ \ddt{\rho \u} + \div ( \rho \u \otimes \u ) - \div ( \mu_{\eff} \grad \u ) = - \grad p' - \vec{g} \dprod \vec{h} \grad \rho \]
For constant density applications this can be further simplified to
\[ \ddt{\rho \u} + \div ( \rho \u \otimes \u ) - \div ( \mu_{\eff} \grad \u ) = - \grad p' \]
For examples of the use of this variable transformation, see:
Copyright © 2018 OpenCFD Ltd.
