Some cases can be reduced to their equivalent simplified systems by taking advantage of dimensionality, symmetric and cyclic behaviour. In OpenFOAM, this is achieved by the application of constraint conditions, e.g. for
Available constraint conditions include
Constraint conditons are specified using the <constraint type> type entry in the $FOAM_CASE/constant/polyMesh/boundary file:
patchName
type <constraint type>;
The field type entry typically takes the same value as the boundary mesh type, with additional properties as required
patchName
See also
Copyright © 2016 OpenCFD Ltd.
