atmBoundaryLayerInletOmega boundary condition provides a generalised log-law type ground-normal inlet boundary condition for the specific dissipation rate, i.e. omega, for homogeneous, two-dimensional, dry-air, equilibrium and neutral atmospheric boundary layer modelling.atmBoundaryLayerInletOmega boundary condition inherits the traits of the atmBoundaryLayer, and inletOutlet.The ground-normal specific dissipation rate profile expression, i.e. omega ([98], Eq. 13):
\[ \omega = \frac{u^*}{\kappa \sqrt{C_\mu}} \frac{1}{z - d + z_0} \]
where
| \( \omega \) | = | Ground-normal specific dissipation rate profile [1/s] |
| \( z \) | = | Ground-normal coordinate component [m] |
| \( d \) | = | Ground-normal displacement height [m] |
| \( z_0 \) | = | Aerodynamic roughness length [m] |
inlet
type atmBoundaryLayerInletOmega;
flowDir (1 0 0);
zDir (0 0 1);
Uref 10.0;
Zref 0.0;
z0 uniform 0.1;
d uniform 0.0;
// Optional (inherited) entries (unmodifiable)
kappa 0.41;
Cmu 0.09;
initABL true;
phi phi;
C1 0.0;
C2 1.0;
// Conditional mandatory (inherited) entries (runtime modifiable)
value uniform 0; // when initABL=false
| type | Type name: atmBoundaryLayerInletOmega | word | yes | - |
