atmBoundaryLayerInletVelocity boundary condition provides a generalised log-law type ground-normal inlet boundary condition for the streamwise component of wind velocity, i.e. u, for homogeneous, two-dimensional, dry-air, equilibrium and neutral atmospheric boundary layer modelling.atmBoundaryLayerInletVelocity boundary condition inherits the traits of the atmBoundaryLayer, and inletOutlet.The ground-normal streamwise flow speed profile expression (([99], Table 1), ([63], Eq. 6), ([24], Eq. 5)):
\[ u = \frac{u^*}{\kappa} \ln \left( \frac{z - d + z_0}{z_0} \right) \]
\[ v = w = 0 \]
where
| \( u \) | = | Ground-normal streamwise flow speed profile [m/s] |
| \( v \) | = | Spanwise flow speed [m/s] |
| \( w \) | = | Ground-normal flow speed [m/s] |
| \( z \) | = | Ground-normal coordinate component [m] |
| \( d \) | = | Ground-normal displacement height [m] |
| \( z_0 \) | = | Aerodynamic roughness length [m] |
inlet
type atmBoundaryLayerInletVelocity;
flowDir (1 0 0);
zDir (0 0 1);
Uref 10.0;
Zref 0.0;
z0 uniform 0.1;
d uniform 0.0;
// Optional (inherited) entries (unmodifiable)
kappa 0.41;
Cmu 0.09;
initABL true;
phi phi;
C1 0.0;
C2 1.0;
// Conditional mandatory (inherited) entries (runtime modifiable)
value uniform 0; // when initABL=false
| type | Type name: atmBoundaryLayerInletVelocity | word | yes | - |
