The condition is specified in the field file for a volumetric flow rate using:
<patchName>
type flowRateInletVelocity;
volumetricFlowRate <Function1>;
value <field value>;
Field file for a mass flow rate:
<patchName>
massFlowRate <Function1>;
A uniform plug flow is set by default. To set the profile according to the downstream cells:
extrapolateProfile yes;
To convert from a mass flow rate to a volumetric flow rate:
rho rho;
To convert from a mass flow rate to a volumetric flow rate for incompressible flows:
rhoInlet 1.0;
Copyright © 2016 OpenCFD Ltd.
