U, to generate synthetic turbulence-alike time-series for LES and turbulent DES flow computations from input turbulence statistics.DFM or FSM, a random number set (mostly white noise), and a group of target statistics (mostly mean flow, Reynolds stress tensor profiles and length-scale sets) are merged into a new number set (stochastic time-series, yet consisting of the statistics) by a chain of mathematical operations whose characteristics are designated by the target statistics, so that the realised statistics of the new sets could match the target. Random number sets ---->-|
DFM or FSM ---> New stochastic time-series consisting
Turbulence statistics ->-|
DFM and FSM is that FSM replaces the expensive-to-run streamwise convolution summation in DFM by a simpler and an almost-equivalent-in-effect numerical procedure in order to reduce computational costs. Accordingly, FSM potentially brings computational resource advantages for computations involving relatively large streamwise length-scale sets and small time-steps.Required fields:
U | Velocity [m/s]
<patchName>
type turbulentDigitalFilterInlet;
n (<nHeight> <nWidth>);
L (<L1> <L2> ... <L9>);
R uniform (<Rxx> <Rxy> <Rxz> <Ryy> <Ryz> <Rzz>);
UMean uniform (1 0 0);
Ubulk 10.0;
fsm false;
Gaussian true; // always false for FSM
fixSeed true;
continuous false;
correctFlowRate true;
mapMethod nearestCell;
perturb 1e-5;
C1 -1.5707; //-0.5*PI;
C1FSM -0.7854 //-0.25*PI;
C2FSM -1.5707; //-0.5*PI;
| type | Type name: turbulentDigitalFilterInlet | word | yes | - |
| n | Number of cells on turbulence generation plane | tuple of labels | yes | - |
| L | Integral length-scale set (Lxu Lxv Lxw Lyu Lyv Lyw Lzu Lzv Lzw) [m] | tensor | yes | - |
| R | Reynolds stress tensor set (xx xy xz yy yz zz) [m2/s2] | symmTensorField | yes | - |
| UMean | Mean velocity profile [m/s] | vectorField | yes | - |
| Ubulk | Characteristic patch-normal bulk flow speed [m/s] | scalar | yes | - |
| fsm | Flag to turn on the forward-stepwise method | bool | no | false |
| Gaussian | Autocorrelation function form | bool | no | true |
| fixSeed | Flag to fix random-number generator seed to 1234 or generate a new seed based on clock-time per simulation | bool | no | true |
| continuous | Flag to write random-number sets at output time, and to read them on restart. Otherwise, generate new random-number sets of restart | bool | no | false |
| correctFlowRate | Flag to correct mass-inflow rate on turbulence plane in (only) streamwise direction | bool | no | true |
| mapMethod | Interpolation-to-patch method | word | no | nearestCell |
| perturb | Point perturbation for planarInterpolation mapMethod | scalar | no | 1e-5 |
| C1 | Model constant shaping autocorrelation function (KSJ:Eq. 14) | scalar | no | -0.5*PI |
| C1FSM | Model coefficient in FSM (XC:Eq. 14) | scalar | no | -0.25*PI |
| C2FSM | Model coefficient in FSM (XC:Eq. 14) | scalar | no | -0.5*PI |
Options for the fsm entry:
false | Method due to (Klein et al., 2003) true | Method due to (Xie-Castro, 2008)
Options for the Gaussian entry:
true | Gaussian function false | Exponential function (only option for FSM)
Options for the mapMethod entry:
nearestCell | One-to-one direct map, no interpolation planarInterpolation | Bilinear interpolation
Patch-profile input is available for two entries:
R | Reynolds stress tensor UMean | Mean velocity
where the input profiles and profile coordinates are located in:
Coordinates | $FOAM_CASE/constant/boundaryData/<patchName>/points
R/UMean | $FOAM_CASE/constant/boundaryData/<patchName>/0/{R, UMean}
points file contains a list of three-dimensional coordinates, and profile data files provide a value corresponding to each coordinate.
mapMethod=planarInterpolation option needs point coordinates that can form a plane.adjustTimeStep=true option is currently not fully supported.continuous=true means deterministic-statistical consistent restart (relatively more expensive), and continuous=false means deterministic discontinuity in synthetic turbulence time-series by keeping statistical consistency (relatively cheaper).L, the first three entries should always correspond to the length scales in association with the convective (streamwise) mean flow direction.Ubulk.Tutorial:
