atmAlphatkWallFunction boundary condition provides a wall constraint on the kinematic turbulent thermal conductivity, i.e. alphat, for atmospheric boundary layer modelling.atmAlphatkWallFunction condition inherits the traits of the fixedValue boundary condition.Required fields:
alphat | Kinematic turbulent thermal conductivity [m2/s]
The boundary condition expression is:
\[ \alpha_t = max (\alpha_t^\prime, 0.01) \]
with
\[ \alpha_t^\prime = \frac{u^* \kappa y}{{Pr}_t \ln \left(max(E^\prime, 1 + 10^{-4} )\right)} + \frac{\nu_w}{Pr} \]
\[ u^* = C_\mu^{1/4} \sqrt{k} \]
\[ E^\prime = \frac{y + z_0}{z_0 + 10^{-4}} \]
where
| \( \alpha_t \) | = | Kinematic turbulent thermal conductivity [m2/s] |
| \( y \) | = | Ground-normal height [m] |
| \( Pr \) | = | Molecular Prandtl number [-] |
| \( {Pr}_t \) | = | Turbulent Prandtl number [-] |
| \( \nu_w \) | = | Kinematic viscosity of fluid in the wall cell [m2/s] |
| \( z_0 \) | = | Surface roughness length [m] |
<patchName>
type atmAlphatkWallFunction;
Pr 0.90;
Prt uniform 0.85;
z0 uniform 0.001;
Cmu 0.09;
kappa 0.41;
value uniform 0;
| type | Type name: atmAlphatkWallFunction | word | yes | - |
| Pr | Molecular Prandtl number | TimeFunction1<scalar> | yes | - |
| Prt | Turbulent Prandtl number | PatchFunction1<scalar> | yes | - |
| z0 | Surface roughness length [m] | PatchFunction1<scalar> | yes | - |
| Cmu | Empirical model constant | scalar | no | 0.09 |
Source code
