atmEpsilonWallFunction boundary condition provides a wall constraint on the turbulent kinetic energy dissipation rate, i.e. epsilon, and the turbulent kinetic energy production contribution, i.e. G, for atmospheric boundary layer modelling.atmEpsilonWallFunction condition inherits the traits of the epsilonWallFunction boundary condition.Required fields:
epsilon | Turbulent kinetic energy dissipation rate [m2/s3]
The boundary condition expression is (([63], Eq. 8), ([59], Eq. 7)):
\[ \epsilon = \frac{w C_\mu^{3/4} k^{3/2}}{\kappa (y + z_0)} \]
when \(y^+ < y^+_{lam}\) and lowReCorrection=true:
\[ \epsilon = \frac{2.0 w k \nu }{(y + z_0)^2} \]
where
| \( \epsilon \) | = | Turbulent kinetic energy dissipation rate [m2/s3] |
| \( w \) | = | Cell-corner weights [-] |
| \( y \) | = | Ground-normal height [m] |
| \( z_0 \) | = | Surface roughness length [m] |
| \( \nu \) | = | Kinematic viscosity of fluid [m2/s2] |
<patchName>
type atmEpsilonWallFunction;
z0 uniform 0.001;
Cmu 0.09;
kappa 0.41;
lowReCorrection false;
| type | Type name: atmEpsilonWallFunction | word | yes | - |
| z0 | Surface roughness length [m] | PatchFunction1<scalar> | yes | - |
| Cmu | Empirical model constant | scalar | no | 0.09 |
| lowReCorrection | Flag: apply low-Re correction | bool | no | false |
Source code
